eric 87
- Aug 3, 2021
- Kentucky
- Eric
- GMC Sierra Shortbed
- 305 tbi
got a question. If it sounds like an existing let me know where to find and I will go. I have looked though and didn't see.
Problem. My 87 GMC shortbed 305tbi th400 stock JUST got a carb swap. Its done and we can discuss which is better till the cows come home.....I like both.
The problem is idle it dies. If I go to lightly give throttle it kills it if it hasn't died. IF I get the revs up first and take off down the road it runs stronger than ever with the TBI. Again that may have been the TBI issue. However it will roast the tire/s easily now when it wouldn't think of it before even with a 2.73 gear. It is a light truck though so there is that.
I took the can of starting fluid to the carb gasket and hoses and t fittings etc. At first nothing. Then I got one of those straws from another can and pin pointed the stream. FUNNY THING is...
The two center bolts on the intake (drivers side) when sprayed actually made the engine REV pretty high. Could there be a vacuum leak at those bolts? But then I was able to get the stream behind the throttle linkage a bit better and it too also rev'd the engine a bit.
But the biggest rev came at those bolts repeatedly. SO I got a universal 9/16 socket and lo and behold I got about a half to 3/4 turn on the front bolt of the two. I got about a full turn from the rear of the two. These are the two bolts that are at the different angle than the front and back bolts. Now if there is a vacuum leak on a fresh install of a new intake and new gaskets do I need to pull it completely back off?
One other question. I noticed I didn't put washers under the carb mounting nuts. Do they need washers? I know it would give maybe a little better spread of pressure but.....
I have never had an intake bolt leak vacuum....is that a thing? Of course I can't remember having this bad an issue with idle
IT has had two locally known HOLLEY carb guys who own their shops make adjustments. I bring this up because one had my accelerator pump so tight I think the lever/arm was pushed down constantly. So not sure of his HOLLEY GUY status.
I have myself looked at every holley carb adjustment video from Holley and others. I have set things to base and then made minor 1/8 turns of idle mixture evenly.
It runs good. I have a slight clatter and wonder if I am still a bit lean or if the leak is still existing since I tightened the bolts on the intake.
Timing I have at 8 BTDC. One of the shops had it at 3-4.
Shame you pay people to fine tune things and you end up doing a better job yourself.
What does the folks out here say. IS it possible to have a vacuum leak at those two bolts or is the spray close enough that the gasket above it behind the throttle is pulling it in.
