My '88 V10 Burb came with rear 52's.
Mine came with crappy 3.42 gears, so I didn't bother converting the front axle... I just swapped it out with an axle from a '91 3/4 ton Burb. My axle didn't come with calipers, so I reused my originals even though they are technically different (piston is like 1/8 smaller). It does have the hefty tierod, but other 3/4 ton trucks sometimes have the smaller one.
The rear is a very easy swap too. The holes are already punched in the frame to move the rear spring hangers back for the longer 56" springs (which ride better despite having more leaves-8). Everything I installed in the rear was actually from a 1-ton, with the giant brakes. The 1-ton stuff requires a little more parts swappin. I also used a conversion u-joint for a while (NAPA #447) but eventually had a shaft made with 1350 joints at both ends.
3/4 ton trucks also used a different master cylinder, but I found the 1/2 ton unit works great. It has a better pedal feel, the only downside is the smaller piston makes it more sensitive to proper rear brake adjustment.
