dkraven
- Nov 15, 2022
- Portland, OR
- David
- c25 Sierra Grande
Previously used a Moroso metal core gasket with a new steel pan and overtightened it. Decided to try a Mahle metal core cork one instead as I read cork is more forgiving. Took the time to hammer down the bolt holes and flatten the steel pan and then unfortunately was gunshy about tightening the bolts. As soon as I put new ATF in the entire seam started pouring out fluid.
My question is, is that cork gasket ruined now or can I clean everything up, install it again with a bit more torque, and try again?
