So I’m planning on tearing down my 87’ this weekend to swap my “new” 383 in. I’m currently running a bone stock 700r4 and a 305. I’m confident I’ll need a large, possibly very large, converter for the cam that’s in this thing. Disclaimer, I didn’t build this motor or select the parts. A coworker put it together for his OBS and decided to go LS instead. I’d love to hear everyone’s thoughts on 1: if the stock 700 will survive this swap 2: what size converter do you think it’ll need.
I’ve got a 3:73 Eaton posi that’s going in at the same time.
Here’s the build sheet:
Thanks for taking a look!
The stock trans won't last too long unless you drive it like an 80-year old going to the grocery store. You will also need a converter with a much higher stall than stock. Contact the manufacturer of your cam to obtain guidance on stall speed range for the grind you'll be using. Depending on power levels and pct time at the track (if any), you'll need to case and hydraulic upgrades, starting with:
- Corvette 2nd gear servo assembly (at minimum); should consider Sonnax super hold 2nd gear servo (and 4th gear servo if planning on doing high-speed street pulls in OD, etc)
- Governor mods depending on desired shift points and converter stall
- New detent (TV) cable
- .500 boost valve
- Ground-down land on the PR valve for line to lube
- Pump working surface reconditioning to bring your rotor/slide clearance into spec (.002-.0025 rotor and slide to deck surface clearance)
- Unbreakable pump ring kit (Transgo)
- Updated TV valve (Transgo SK700R4JR shift kit)
- Clutch feed/exhaust holes spacer plate drilled per requirements/vehicle overall set up/intended use
- Certain case and v/b check balls left out, depending on other mods
- MTV upshift valve spring removed
- Line Bias valve spring removed and replaced w/rod to block valve movement
- Modified/shimmed 1-2 accumulator housing w/piston (or Sonnax pinless)
- New rev input drum with wide kevlar lined or Alto red 2-4 band (20% wider than a stock BW high energy band)
- Blocked-off 3-4 accumulator
- Beefed up 3-4 clutch pack
- High energies throughout unit
- high rate return springs in the forward drum (Transgo's kit works fine)
- 4L60E late model bonded pistons and ret spring assembly
- Sonnax reinforcement sleeve kit for the forward drum (comes with it's own coast clutch apply piston).
- Lube mods to your front/rear sun gears to promote better lube to planetaries/ring gears
- Possibly 5 pinion GM OEM front and rear planets
- 07+ 4L70E induction hardened reaction shaft w/bearing
- Sonnax smart shell
Let me know if you need more info or have ?s.
