Darrell Goodwin
- Mar 1, 2020
- Pueblo, Colorado
- Darrell
- C10
Forgive me if this has already been answered; I've looked but still don't understand. I have an '82 "Custom Deluxe" (which is neither) with a 305 engine. It ran great until recently the motor died in the fast food pickup queue. I replaced the coil (wrong) and then the ignition module and that fixed the problem. Then I replaced the rotor, condensor, plugs and plug wires to prevent any other potentially pending untimely malfunction. But now it runs like crap. I figure the timing needs to be set after replacing the ignition components. I bought a cheap Harbor Freight timing light (it has the advance knob but I leave it set at zero.) The timing mark has been painted white, and while looking from underneath, I put a white dot on the opposite side of the harmonic balancer just as a visual reference. It's not 180°, just a rough indicator of how much I've rotated the crankshaft. When I use the timing light, I see the dot, the actual timing mark doesn't appear.
My technique for over 50 years until now has been an 'old-school' method that has worked well for me: I nudge the distributor a little bit and drive a couple miles observing performance. I do this as I handle routine daily business, and as each adjustment improves performance, I know I'm going the right direction. Now it starts usually on the first crank, no longer backfires (but occasionally misses) but I haven't hit that sweet spot where it accelerates with power. The Quadrajet 4-barrell seems maybe a little bit too rich, but how could the timing mark be so far from the pointer that it doesn't even show under the timing light? I carefully changed one wire at a time, so didn't mix them up. It had that plastic identifier on top of the distributor until the new wires went in (they don't have the little bumps to hold it.)
Could the harmonic balancer have slipped? If so, how does that happen and how can it be fixed? Or am I overlooking something that would be obvious to a more experienced person? Tomorrow I'll start from the beginning by cranking to #1 TDC and go from there, as well as verify the vacuum is still as perfect as it was last year when I rebuilt the carburetor. My old-school method has always gotten results pretty quickly, but I've been nudging the distributor numerous times a day for over a week, and while there is improvement, it would be nice to be able to use the timing light and dial it in and lock it down. Comments, criticisms, suggestions are all welcome. I'm an old dog ready to learn a new trick.
