SpeedyTurtle86
- Jun 24, 2019
- Montana
- Tyrell
- High sierra, scottsdale
So I have an 86 half ton 4x4 GMC high sierra. I gotta it from the original owners. About 12 years ago they put a Goodwrench crate 350 in it replacing the 305 that came in it from factory.The OO drove it about 5 years, put 9000 miles on it then had his left knee replaced and couldn't push the clutch any more so it got parked until I came across it about a year ago. I have replaced: mechanical fuel pump, valve cover gaskets, pcv valve and grommet, plugs and cables, rebuilt the carb and pretty much replaced everything I can on the distributor without pulling it and putting a new one in. I CANNOT get it timed it runs fine for about ten to fifteen minutes then dies and acts like it's vapor locked and won't start back up until it's cooled back down. I tried the clothes pin trick, didn't work, that's when I rebuilt the carb and got the same issue. That being said the OO used the carb from the 305 motor when the 350 was installed. I'm thinking they reused the harmonic balancer and distributor as well. Are the timing marks different on the 305 harmonic balancer? Should I pull both the balancer and distributor and replace with parts I know are correct? I'm dying here I traded a $4000 motorcycle for this rig and haven't even been able to run it for fear of damaging the motor!
