Scott89s
- May 25, 2017
- US
- Scott
- C10
I'm going to apologize now for this post as it will be lengthy to cover the details.
71 C10 short box turbo 400 with shift kit 12 bolt rear with 4.10s
Build specs
350 4 bolt .040 over
Flat top pistons
Ported and polished 441 head
Summit k1103 CAM- 214int./224exh. @ 050
Performer intake with edelbrock 600 carb
MSD 6al box, dist(mech advance) and coil
Timing is set to 12btcd and at 3500rpm around 36
Vac at idle is 16hcg steady.
My issue is it still feels like a dog.like Slower than before I rebuilt it. And it's seems to run way hot. If your wonder why I rebuilt it well the Valve seals were shot compression was 120 timing chain had so much slop it was hitting the cover oil pump was plugged ect.
Sent from my SM-G935V using Tapatalk
Build specs
Flat top pistons
