Tie Rod Question
I need to replace my Tie Rods. I have the 7/8", want to upgrade to 1". My question is does anyone make the long Tie Rod with out the steering stabilizer mount? Lets be clear I want solid bar, I don't want the hole on the one end. Do I need to source some custom 4x4 company, or get some DOM tubing?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
ORD maybe? I don't have any of their stuff but it seems to be popular. I was going to suggest Synergy Mfg but I didn't see any square stuff in their line up, I have the Synergy stuff on my jeep and it takes a beating.
https://www.offroaddesign.com/ord-hd-tie-rods.html
nvrenuf
Mobile, Al.
If DOM is acceptable Off Road Design and Diy4x both offer tie rod assemblies.
I don’t know of anyone that offers a upgraded tie rod that’s solid.
The more I think about it, I might just keep the one that's in it and just replace the tie rods. It's not like this Blazer is going to see any hard core 4x4ing. Dirt road, maybe a little flexing.
dvdswan
Port Orchard, WA
Dave
I used ES2234R and ES2233L TREs, 7/8-18 HEX TIE ROD END TUBE INSERT left and right threads, and 1.5" OD / 1" ID DOM .250 wall. I also used the ORD high steering arms that mount on the top of the knuckle. You will need to enlarge the taper hole to fit the 1T TREs.
NOTE: you will need a 2wd steering gear for this IIRC.
gtewolf79
