Ol Blue 2018
- Jan 7, 2018
- Pensacola, FL
- Brian
- V10
1987 V10 TBI 350
Using my trusty "paperclip", I see I have a code 22: Throttle Position Sensor (signal voltage low)
Using a multimeter I see that I have .54 volts at closed throttle and 3.4 volts at wide open throttle. My service manual says I should have about .5 volts at closed throttle and about 5 volts at wide open throttle.
I am thinking this means replace the TPS. Is this correct?
Thank you and let me know if this sounds right.
