Throttle cable bracket
RamblinGMC
Clovis Ca
Eddie
c2500
Does anyone have a pic of where the throttle cable bracket goes/mounts on a 350? Converting to a 350 and acquiring parts. Truck is a 1982. Thanks!
CheemsK1500
K1500
If the the truck was a 305 originally, everything should be essentially the same. If it was a 6 cylinder or diesel of some sort, it probably won't be too much different and can probably be modified to work. If not, there are plenty of adjustable and custom throttle brackets you can rig up to work.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I have these of a 1985 carb 305. Should be same as 350. I can try to get a closer up if needed
Turbo4whl
Downingtown, PA
Wayne
Your truck, the original throttle bracket would bolt to the two rear carb mounting studs. Running a Holley, I cut the bracket and added a support to a manifold bolt.
Earlier engines the bracket bolted to two manifold bolts.
RamblinGMC
Clovis Ca
Eddie
c2500
Converting from a 6.2 to a 400 SBC. Just trying to figure out where this bracket mounts, now that I know I will have to modify it to work with a Holley, actually going to run a Quickfuel. Thanks for the help!
Doug Hampton
