this is the oddest thing thing..ever..i have no headlights after changing my WP
stlbob
St.Louis
bobby
91'
k3500 4x4 Burban'
Yeah..Pump went south.No big deal changed it out again no biggie..Had to go pick up the wife pull the headlight switch dash lights,Buuut no headlights.
Grabbed a test light and used the battery ground to the headlight plug in and i get a light.Now i know the headlights have their own ground in the plug in.My running lights are on the tail lights on..
SO damn...any ideas at all please hit me up.
notime2d8
Alabama
Ken
K5 Blazer
Did you have any wires running from the starter to the cab or alternator that got snagged? Mines ran right past the water pump. Also check the grounds for the headlights​. I think there's one on each side. If all this fails. Get a test light or muiltmeter and check the voltage on each plug with the switch on.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Agree with #Notime
Sounds like a low voltage or bad ground, maybe to high of a resistance in the wires leading up to the plugs, but all else fails test the switch for resistance across contacts maybe pooched. Clean all of the contacts, look for the green monster and replace head lights as a last resort measure(throw parts at it out of frustration!)
Tank6x2
Kurt
C30
Check
Check
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Any luck yet?
I know the headlights are run in parallel, but what's the possibility that you pulled the connections loose in the headlight plugs?
Do you have no headlights at all? Only one? Lows or Highs only?
Have you tried putting the old pump back on to see if that fixes the headlights? :hidesbehindsofa:
Ok, I'm outta here now. :Bye:
:ehcapt: I wasn't fast enough. Some dude came chasing me outta there and I think it was a ratchet I got hit in the back of the head with. :think:
gmachinz
Harnessworx Inc
Iowa
Jabin
Oldrider
NC
k2500
LOL.
I have to agree that you probably upset the wiring while working on the wp.
the old wiring does not like to be squished or moved around.
chevyBlu
