Andrew Koetz
- Apr 2, 2023
- St. Paul, MN
- Andrew
- K20 Chevy Suburban
- 5.7 350 V8 208 T-Case; 10 bolt front 14 bolt semi rear
I put a brand new thermostat in my 84 K20 Chevy Suburban 350 last year & toook note the gauge was not working so I changed the thermostat and the sender on the block; still no indication of temperature. At this time I installed a new temp gauge in the dash cluster; and things started working; until I noticed the temp went up to 260 degrees in apprximately 10 minutes run time and teh truck was not very hot; cold start. Is there possibly a ground I am missing from the dash to the firewall? I am tempted to try and run the truck without a thermostat just to see what happens for a day. Also keeping the old addage in mind; "just because it's new does not indicate it will work properly."
