Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
https://www.chevydiy.com/chevy-small-block-engine-guide-exhaust-systems/
they include a section on tuning secondary tube length. they use a resonator box to blind the engine to the mufflers or whatever comes after the resonator box. say your engine's optimal secondary length is two feet, you install a resonator which is just fancy for something that disrupts the exhaust pulse to optimize flow. most people talk about resonators as a type of muffler, when the science shows they have a purpose in a tuned exhaust in conjuntion with the use of a muffler.
so the correct order would be header/manifold, collector, secondary tube length, resonator, pipe, muffler. does a crossover such as an x-pipe replace what the resonator does or should I run resonators, then x-pipe, then muffler? most people suggest running the crossover as soon as possible after the headers for max scavenging effect. this is also where the article says to place resonators.
maybe the book was written before x and h-pipes were popular. if anyone has some actual knowledge to validate any of this, it would be greatly appreciated. I already have the parts sitting around so I could try it both ways. I just don't want anymore welds than necessary on my exhaust. I'm kind of weird with my OCD.
