OldBlueDually
- Jun 8, 2020
- Minnesota
- Justin
- 1976 GMC
- C30
- 455 Olds
Hey Gents, I currently purchase two 60 inch straight lengths of 5/16" line for my new transmission (Olds TH400 in my dually), and was going to bend them to fit, probably have to re-flare/double-flare one end which is fine as I have the tools.
Then I got to thinking, everything is "in the way" and this is probably going to suck to do-hours worth of time, so I started debating about getting flexible transmission lines. However, the reviews I read are not good enough to make me feel comfortable to buy any.
My question: has anyone had a good experience using flexible transmission lines? If so, what did you use & are you happy with them?
OR--would you say "screw flexible lines" and just spend the time to bend up the metals ones & go?
Thanks!
Thanks!
