- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
This is a TBI 350 Chevrolet Motor originally out of a 94 Z71 Pick up. Cast # is 14093638. It will come up as 2 or 4 bolt main, roller or flat tappet cam. Its been my experience the truck engines ARE 4 Boltt Main but are Flat Tappet motors. However, they are drilled and tapped for the spider for the roller lifters and can accomadate the roller cam also. The motor will also be a single piece rear main seal. $100
Motor has not been cracked open. Comes with block, heads, TBI intake, Exhaust manifolds, Oil Pan, Valve Covers, Harmonic Balancer and Serpentine Pulley just as pictured. Motor has been sitting for over a year covered up and is not seized. The motor was pulled because it was tired and smoking. I was going to rebuild it for one of my project trucks but now going with a Big Block Olds motor. Keep in mind, you are buying a rebuildable core. I woudln't consider this to be a running ready to install motor although it was running when pulled.
