- Sep 1, 2018
- Washington State
- Craig
- 1973 (have two), 1985
- K10, K20, C20
- 350, 454, 6.2 Detroit
As a retired machinist, I can tell you about taps, and there is a big spectrum. Cast iron blocks have graphite, which is by nature slippery, machinist handbook lists a few things to use for lube. I like black sulfur based cutting oil, can use it for most materials, except, some aerospace and nuclear industry. Also kerosene and black oil excellent in aluminum. You have straight, spiral, former, spiral point and etc, each designed to do a certain job, in certain materials. Taps are made in three tapers, tapered, plug, and bottom, with the majority being the plug style. Bottom taps will get the job done, but require much more torque, because there is less lead in, conversely, taper style has less torque because of the long taper. Torque is what breaks taps, that and dry tapping. Good brand taps: Greenfield, Cleveland, Accupro good less expensive tap, Guhring, Emug highest quality, but you won't be needing them, here for comparison. HF, junk, Irwin barley ok. I probably have close to 500 taps in the shop, can tap anything, so having said that, buy good high speed steel (NOT CARBON STEEL) plug tap and a good tap wrench. Here are a few pics, as they tell the story, and while SS bolts really do not work, better grade 8 or 10 and ground with a hook (positive rake angle), NOT A FLAT, will nor cut, but may form softer non ferris materials, personal experience. Pic 1) right hand cutting, spiral point (pushes the chips forward, or down) , plug style, shows the positive rake. 2) Spiral tap, used in softer materials pulls the chip out like a drill, either plug or bottom style. Tap handles, top greenfield, it is about fourty years old, tapped thousands of holes, comes in several sizes, expensive, but worth it. Bought mine used at Boeing surpluses, Auburn WA. Middle is homemade, also fourty years old, still has it's uses. Bottom, General brand ratchet tap handle, also fourty years old, and excellent choice for the home shop, make two sizes, have them both. Bottom is a specialized tap, it is a former tap, forms (like forges) the thread making the metal denser, there for stronger as much as 30%. Used mostly in non ferris applications requires a larger tap drill.
