Tank Selector Valve
custodian
Catawba
William
5.3 LS, 350
Is there a procedure in testing the fuel tank selector valve?
dvdswan
Port Orchard, WA
Dave
1 wire or 5 wire? 3 port or 6 port?
1 wire you can take a 12 v source and touch it to the single post and here it click. No noise its dead. Be sure you have a good ground to the body.
custodian
Catawba
William
5.3 LS, 350
5 wire, 6 port.
dvdswan
Port Orchard, WA
Dave
You will have to look up the wiring diagram for you year of vehicle and find out would pin is the signal to switch the valve.
If the vehicle is the 73 you have listed, then you should just have a 1 wire, 3 port unless the PO put in a newer style valve.
custodian
Catawba
William
5.3 LS, 350
I'm working on an 85 C10 that I'll be giving to my youngest granddaughter. I gave the 73 to my oldest granddaughter (the 73 is single tank).
ak4life
alaskan born, fed and bred.....lol.
nevada
chris
81/84 gmc, 2001gmc, 2003 gmc, 2005 chevy
longbed squarebody, longbed 4dr extended cab, yukon sle, 4dr ext. cab
383, 6.0, 5.3, 5.3
What about the 5 wire ? Testing the same ? Thank you
dvdswan
Port Orchard, WA
Dave
Yes, this is the basic set up. 5 wire runs the intake pumps.
Doug Hampton
