77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
I had a shop install my magnum doubler in my '77 K20 probably 2 years ago... should have done it myself. They used 2" square stock to drop the transfer case/doubler down from the frame. I don't like this. I have a rear driveline vibration now. Have to tilt the rear axle pinion down or raise the transfer case back up where it should be.
I removed their 2" drop and replaced it with some 1.4" spacers. This helped my driveline vibration a bit. Can't bring the transfer case up higher- as the 205 would hit the transmission hump.
Is the late 70s 4x4 automatic transmission tunnel the tallest one out there? Any aftermarket one that are taller?
This would probably be the best option. I was also thinking of ORDs 1" bodylift but am not a fan of bodylifts. I also have a 5th wheel hitch I'd need to get spaced up also.
I also removed the second crossmember and the skid plate as they just bolted it on with one bolt to a bracket for the gas tanks.
