Dads84
- Dec 25, 2018
- Decatur Indiana
- Troy
- K10 scottsdale
I bought a 8' bed to use on my truck ( I only need drivers side and front bed panel ) the person I bought it from, put new bed sides on it, then left it outside ( a year or two) with only the coating that was on it from supplier . is there a easy way to get surface rust off? Or will I need to run a DA all over it ,then epoxy primer it. I tried a small area ,and it cam out fine ( gray primer spot). I only have 225.00 dollars in it, so I thought it was a good deal.
