straub
- Jan 12, 2020
- allport PA
- pete
- K10
ok, i got the truck and it would run but they had the idle turned way up to make that possible. so once i brought it back to a normal idle it burped and chugged til it shut off. so i tried to check the timing best i could cause there is no tab. also went through the plug wires, found one that was completely broke and two others that were barely hangin on, fixed those. all 8 are firing,cap and rotor look decent. adjusted air fuel on front of carter comp series carb. there is no choke on it? maybe thats the reason for the idle being up? it is running much better than it was but still is missing and studdering at idle. revs up fine with a little backfire but maybe because the exhaust is cut off three feet behind the headers? also kkep shutting off. it will fire right back up and run fine for like 90 seconds then just die? planning on rebuilding the carb, i think this is the cause of most of it. don't know much about carbs. but seems like it is clogged up and then just runs out of gas. any ideas? just trying to get it easier to pull in and out of the shop. thanx
