Burban
Bear
- Sep 28, 2015
- Uranus
- H
- Suburban
Let me preface this by saying, I'm not looking to build a bogger, rock crawler, or any kind of performance machine, I just want to get this old sucker running again, for fun, and maybe occasional trips to the lumber store.
This is a carbureted '83 350 with a Q-Jet, that mice nested in, and pissed all over the choke plates. I let it sit, for several years, and now it's stuck, the starter can't kick it over, I can't turn the pulleys.
My current plan is to remove the plugs, pour a mix of acetone and brake fluid down a funnel and tube into each plug hole, put the plugs back in loosely, let it sit, repeat the process, and let it sit a bit more, then try and turn it over.
If anyone has suggestions, I'm all for it. Ideally, if I could just pour 10 gallons of diesel into the oil filler, go on vacation, come back, drain it, add oil, and start it, I'll do that
Was kind of surprised my search didn't find any other stuck block threads.
