Stock height
akchevrolet
Andrew
Does any one know the height difference between the front and rear of a 1987 r10? Want to level it.
chengny
Here are the ground clearance heights for the 86 C series - maybe it will help:
74 Shortbed
Ground clearance is based on factory tire dimensions, if tire sizes have been changed need to compare both to get an accurate measurement..
yevgenievich
Place
Name
Year
Model
Size
From what I have seen 1/2 tons were already pretty much level, but the wheel arch is different front to back.
chengny
Oh sorry, I kind of got the impression that he was looking for the difference in height (from front to back). And also that his tires were all the same size.
akchevrolet
Andrew
the tires are stock size but wheels were an inch wider. and yea i was just wanting the difference. thanks yall
yevgenievich
Place
Name
Year
Model
Size
Ground clearance in the rear is not really affected by the suspension but depends on the tire size and type of diff, while in the front it might depend on the spring and tire combo. Overall height or height to the body line might be the more correct measurement.
74 Shortbed
That is correct, with the same size tire if you have the same distance between the tire and fender front and back, truck will be a tad higher in back, perfect stance IMO..
Doug Hampton
