Steering stabilizer K30 install
SMC2224
Indiana
Skyler
K30 Crew Cab
I installed this Skyjacker steering stabilizer and torqued to the specified 65 ft-lbs, however since it is a tapered fit, I was unsure if it should sit flush against the drag link. I can't recall if the old one did and the instructions are unclear. Any advice on if this is fine?
projo198
Lawson MO
James
I can take a peek at mine tonight, just installed it recently as well.
At any rate I would think there is some play there as long as you keep an eye on lose play every once in awhile. I've removed shocks that looked damn near like they were at 45 degree angles!
amadrid
