Steering shaft
Itsme0903
Eddie
I’ve got an 84 and just put a new rag joint on but I’m having an impossible time getting the steering shaft on. It’s got two plastic pegs in it. Can I just pull those and collapse it to get it back in?
Itsme0903
Eddie
Yeah. I got the right spine count I just cannot get it to collapse so I can reinstall. Gonna try and heat it some. Thank you
Dmack
Central OR
Dave
The plastic pins are put in at the factory to hold length until a collision, where the impact will push the shaft into itself, instead of jamming a steel steering shaft through your chest. I would take a small drill bit to the pins first, then a little localized heat should allow it to collapse.
nvrenuf
Mobile, Al.
If you have a torch burn them out. Do not replace.
dbrannon79
