Steering Column Swap
bigge31566
GA
Ervin
Will a 1984 steering column with tilt and cruise work in a 1983 steering column without tilt and and without cruise, don't need cruise. I have a 1983 with dimmers on floor
J Knight
Baytown TX
82 Chevy
350ci
Yes, you dont have to use the column mounted dimmer switch or cruise. Ignition switch, neutral safety switch and turn signal switch is the same.
bigge31566
GA
Ervin
all plug ins the same
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
It will work as is but if you dont like the way it looks just change out the lock housing, turn signal switch and turn signal switch lever. Maybe $50.00 in new parts should do it.
brentjo
