Steering column rebuild
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
As the title states, I’m rebuilding the column that’s going in my 81 GMC. It’s all back together, ready for some paint. My question, is there a deal or dust boot to keep crud out of the lower bearing? I took apart 3 different columns from various year GM trucks, all the bearings were dry of grease, and none had anything covering the bearing. I find it had to believe all 3 are missing the same part, and equally had to believe the bearing is open to the elements. Thanks!!
Nope, they were just open to the elements.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Ok, I guess if it lasted as long as it did it will be fine for another 40 years. Thanks
Camar068
10 yrs Air Force
just installed one on the tilt column I haven't put in yet. I added grease to the bearing because there was none to be found. Normal or is it supposed to be dry? Can't imagine dry.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If it’s the one I’m thinking it is it was from an 89 less time and mileage and element exposure do to the year. Lol
legopnuematic
Licensed Junk Dealer
MO
Spencer
The one in my 79 was locked up pretty good, luckily the steering shaft was able to turn inside the race so it still could be steered when moving around
2manysquares2care
