Squeaky steering
85K2500
Boise Idaho
Cooper
K2500
350 small block
I have a 85 K2500 and I was wondering if anyone knows why there is a squeaky noise when turning at little to no speed. I haven’t replaced anything to figure it out yet but wanted to eliminate some things before spending money on it.
fast 99
Spokane, Washington
Usually it is a dry joint. Just try greasing it. Look for rust at each joint. Jack up, check for looseness at each joint and linkage.
350 w/203
From where? Column or outside?
85K2500
Boise Idaho
Cooper
K2500
350 small block
it is coming from outside
350 w/203
Then go to @fast 99 at post #2 and take his advice. To shorten the time, get a friend to help to turn the wheel and don't forget to use jack-stands!
Rusty Nail
Rusty
350sbc
You have to grease the suspension Junior. Regularly, like every oil change.
There are 13? 14? Spots to grease in a k2500 not including driveline. Might be 17 spots need lube. REGULARLY, like every oil change.
Spraying your front end with WD-40 doesn't count.
scrap--metal
MN
Calvin
'85, '81
K10, K20
Depending on the level of experience here, it could be a whining power steering pump that's low on fluid.
Squeaky noise vs whine...
2manysquares2care
