77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
For sale is the manifold that came on my GM HT383 engine. I bought the engine in August of 2014 and have switched to another intake manifold due to cold weather issues. If you don't live in the far north I'm sure it would be fine for you.
GM Intake #12496820. Dual bolt pattern spread bore manifold. Has provisions for EGR. Comes with EGR block off plate, GM 180* thermostat P/N 10202456 and GM thermostat housing # 10108470
http://www.summitracing.com/parts/nal-12496820
Description:
This Vortec manifold was designed for ultimate horsepower and torque to be used with Vortec cylinder head, P/N 12529093, 12558060, 12497186 or 12464298. This aluminum four-barrel manifold will accept Holley or Quadrejet carburetors and is EGR equipped. Use intake manifold gasket P/n 12529094 and eight special manifold bolts P/N 12550027. You can use EGR P/N 17052693.
Manifold height: measured from end rail of block to carburetor mounting flange - rear - 5-1/4", front - 3-3/4"
To hook up EGR with this intake, following parts are required:10220275 EGR pipe, 12552329 fitting, vortec exhaust manifold # 12557828, 12557828DT (tapped for O2 sensor) or ED1476 weld-on fitting kit for use with headers.
To plug EGR pipe hole in intake, use GM 12556596 or a 10AN plug.
$165 + shipping
Description:
$165 + shipping
