c1084
- Sep 18, 2013
- roanoke,va
- barry
- c10
Hi, new to this site. I recently acquired a 1984 C10, longbed fleetside. The speedometer is reading way too fast, off maybe 18-20 mph at highway speeds. I suspect the trans (700R4) has been replaced with a unit from another vehicle that had a different axle ratio or tire size. The tires are the size that came on it stock (235/75/15) and the rear axle ratio is 2.73, also correct according to the option codes. Can't I just change the speedo gear to correct the inaccurate reading? Counting teeth isn't any help since I'm pretty sure that gear is wrong for this vehicle, and most of the ones specified as possibilities are obsolete according to the local GM dealer. How do I specify the correct one, and where can I locate it once I do? Any info appreciated. I hate speeding tickets.
