andrewgasc
- Oct 3, 2023
- New castle Kentucky
- Andrew
- R3500
- 454 TBI
Hello all, Recently bought a 91 crewcab square with a 454 TBI with a 4l80e behind it, after vehicle has been shut off, after more then 30 seconds it won't restart, found injectors to not be pulsing on startup/spraying fuel. If vehicle is started with starting fluid it will stumble to life slowly, then idle fine, will run as long as you please after that, runs good.
Just replaced ICM after following someone's testing that using a simple test light connected to a battery source, touching the purple wire on the 4 wire connector of the ICM would pulse the injector, did that, injector would pulse. So per that troubleshooting one should replace the ICM, no change. Have pulled the upper TBI housing off to check regulator diaphragm, not torn, no debris.
When I changed ICM noticed like rust or dust powder that seemed excessive around ICM.
Using extension leads from injector connector to injector terminals I remove the injector, sat in cab with door closed, cranked, no pulsing. Connected battery to one side of injector, then would tap ground against other pin, injector would pulse in my hand. I do have 12v on one side of each injector clip. Both injectors acted the same. Both injectors ohm at 1.2 ohms. Have checked all fuses in cab, none blown, replaced all with new anyway.
Just looking for insight in to this, owned a 350 TBI before, never experienced an issue like this.
