farm truck
- Apr 1, 2022
- Laguna Hills, CA
- chris
- C2500
OK - this may end up being a long post, so I appreciate your patience. I am also admittedly medium-skilled when it comes to the Chevy 350. I have had a million cars and bikes; this is my first GM product.
The issue is that the proper locations for the Sniper temperature probe (on the right or left side of the thermostat housing in the intake manifold) are unavailable. Standing in front of the truck, the RH threaded hole is plugged and this galvanized plug is HOPELESSLY stuck forever (picture 1)
That's why I disconnected the temp probe for the dash temp gauge and put the Sniper probe in it's place. (picture 2)
You can see the loose dash gauge temp lead in picture 1. Funny thing, the dash gauge still reads temperature! Here is where my knowledge hits a brick wall: is the sensor in picture number 3 for water? Or oil pressure? If it's for water temp, why would there have been two of them?
So here is my two fold dilemma:
1. The Sniper gets up to temp just fine...... but I "think" that's because the previous owner DID put a lower temp thermostat in her (165F?). This truck rarely gets up to 195 F, and never in winter. I want to get the temp up, but not at the expense of low water flow across the Sniper probe.
2. Where to move the Sniper probe to when I put in the 195 F thermostat? Can I just drill a small hole in the thermostat, as I have read here and elsewhere? Or can I just add a tee on the heater core supply or return (pictures 4 & 5)? If so, which one is better?
Thank you!
Thank you!
