Dutch Rutter
- Aug 13, 2013
- Independence, Or
- Joshua
- K20
See the photo. Is fixing this as easy as replacing the seal around the shaft? I ended up spending a whole $15 on a new seal and the special tool to pull the old on at Napa. Should get those next week.
I'm just not sure if that's the real issue or if something else is going on here. The fluid I see is a drip or two off the shaft itself. And I believe it runs back to the pan bolts in the second picture. The other side is clean and clear.
