PhotonFanatic
- Aug 6, 2022
- Arlen, TX
- Wilhelm
- Silverado
I've determined that my 700R4 transmission is leaking on my 87 R10 truck. Seems to be the shift shaft seal. Is there any special procedure for removing it? I went looking for the usual youtube video, but there doesn't seem to be any showing this particular job. It's clear that the fluid is coming out of that hole, and it even leaves a red droplet hanging on the end of the shaft.
I seem to remember needing to drill a hole in the ones for the TH400 in order to be able to wiggle it outta there. Either that, or use a special tool. Hopefully the 700R4 has a simple removal. I did find this so maybe it's the same as the TH350 and 400:
