Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
i have a 96-99 l31r. just a 4bolt truck motor from those years. i picked up everything from a donor motor today: accessory brackets, all accessories and pulleys (a/c, alt, water pump, power steering pump, idler, blah, blah), the intake system(manifold, vortec injection, etc), distributer, starter, exhaust manifold…think everything but the long block…but he forgot the fan and fan clutch, oh well.
i was only looking for the accessory brackets when on CL, but i got everything for $100. i figure i can sell the a/c compressor, intake/injection stuff, distributer and all the other crap for what i paid.
besides the brackets, i'll use the alternator and starter for now. as for the water pump, i can't bring myself to installing a used 20 year old one no matter the condition. so what do you guys recommend?
1. the water pump from a 94 pickup should work right? spins the right direction, doesn't have all the extra holes like a 96 does for coolant headed to the intake…
2. pulley from a 94? will that line up correctly with vortec serpentine accessories?
3. anyone make a solid, non clutched fan that has blade pitch to run the serpentine direction as apposed to the v-belt direct drive fan i have already from my carb sbc? if not, should i meet back up with the guy to get the fan setup from the 97 motor? i'd rather a direct drive clutch-less fan if possible. i have the larger diesel radiator/shroud if that matters. not sure if the fan is bigger than the same year 350s..
4. i'll be running a/c delete, and hence selling the compressor and lines unless its worth hanging on to to convert the truck in the future. not even sure about refrigerant types and availability of some of the older refrigerant types in California.
