Save money power window rebuild
hopefulbull
Fenton mo
I have a 79 K5 blazer im rebuilding. It has power windows but all the guts (regulator etc.) Need to be replaced to. When looking at the LMC catalog the stuff before 1982 is way more expensive.
Can I use all of the power window parts from an 82 in my 1979?
Check Rockauto.com. Much more reasonable priced and OEM parts are available
hopefulbull
Fenton mo
Just checked and the prices are cheaper, but there is still a huge difference in the price in the stuff pre 82 versus 82 and up.
Can I use 1982 and up power window guts and motors in my 79 door?
No you cannot. The are different
hopefulbull
Fenton mo
Thanks for the quick response.
Camar068
10 yrs Air Force
keep an eye out for dented up doors that will work on yours on facebook and craigslist
hopefulbull
Fenton mo
So can I swap the doors then use the cheaper guts and motor?
Camar068
10 yrs Air Force
if the doors are dented and rusted up they'll be cheap and maybe the window hardware is good.
hopefulbull
Fenton mo
Good thinking.
Really it's just the motors are so expensive for the pre 82 stuff. We are taking $100 vs $20 per door. All of the other items are reasonably priced.
hopefulbull
Fenton mo
What this all boils down to is cost. I can buy a new regulator and motor for 82 -87 cheaper than I can buy just the motor for 77 - 81 doors.
I did a bunch of digging thought part numbers online today. I think it's possible to use the newer 82-87 parts. I attached a pdf with everything I found. Please check it out and share your thoughts.
  • blazer windiw info.PDF
If you’ve done the research and have concluded it’s possible then jump into it and report back the results of the attempt. That way, when the next person asks we can show them the thread of the real world results of the attempt.
hopefulbull
Fenton mo
That's the plan parts will be ordered tomorrow. I just wanted to see if someone saw something I missed.
Camar068
10 yrs Air Force
helpful tip. Get the part #'s from where your going to order and see if amazon has it. If anything you might save shipping. Example, RA had the fuel tank I wanted for $100, but wanted over $30 shipping. I got it on amazon for $105. Prices in the example are not exact....can't remember off hand, but they were that far off if not more after shipping for the exact same manufacturer/part#.
Don't forget we get 5% discount on RockAuto.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
dorman are cheap and work great...don't kmow if you can retro fit on yours but...
dannyphx
