Fat 454
- Jul 24, 2012
- Australia
- Andy
- C20 Suburban
Hi all, can anyone with re-build experience on these pumps help with advice on any of the following please -
For context I am re-building a P type pump from a '91 K2500 4x4 OBD, with a 350 vortec and serpentine drive belt. Appear to have lost pressure in the steering system ( replaced pitman arm, checked steering box, new hoses etc. etc. )
Is the pump rotor outside face ( between the vanes ) supposed to be smooth, or grooved ? ( rough "wear" grooving, not clean machining rings ) ?
I pulled this one down and found lots of gunk on the magnet, and thought the rotor was galled, however when I stripped another pump to compare, it looks the same ( maybe both bad ? ) Evil bay seems to show both smooth and grooved - any thoughts ?
Inside of the rotor cam is unmarked, and vane edges are polished also. Assume that is where the hydraulic seal is made :
Next, assume the flow control valve works under pressure, as I have cleaned the gauze filter screen, but cannot blow through it. Assume thats how its meant to be ( ie. not blocked ). I can't get the filter nut off, as cannot hold the circular plunger valve body. Assume there is a factory tool for dissasembly ( j wrench with peg to hold in one of the bleed holes ? )
The Reservoir on this ( '91 ) model has a mid mounted return line ( top ), whereas all the other ones I have located the return at the base ( lower ). Are they OK to interchange ( the high mount one has a much longer steel return line and it has been partially crushed, so an concerned it may restrict flow ...
Finally, any tips for getting the ( tiny ) rotor shaft retainer snap ring off ? The newer box had a circular section ring ( top ) that popped off easy, but the older one ( bottom ) has a flat ( piston ring section ) snap ring. Its too small for regular snap ring tools, and the square section wont pop over the land. Its driving me crazy !!..
thanks for any help
thanks for any help
