rpcraft
- May 31, 2016
- Texas
- Robert
- Jimmy
- LS 6.0 364 CID
To be honest I would keep the 3.73's for right now if it is not causing any overheating or other issues and just live with it for a while and then just look into an OD trans. If you do have some overheating check the normal stuff. Radiator, leaks, flush the motor, install a recovery bottle, and probably replace the clutch fan with either a new clutch or an electric pull fan that is T-stat controlled. Swapping out gears isn't just a matter of a crush sleeve and pop in the new R&P depending on most axles. Not sure what you are running. One ton full floaters are actually way easier to swap but if its a 10 or 12 bolt then its not, and if they are not putting in new gears and doing a proper setup then you will have other complains down the road to look forward to. The gears may be affordable but a new setup will require at least new bearings, spacers, accurate measurements, and then there is labor (assuming someone is installing it, unless it's a brother or good buddy).
Maybe you can find a late 90's OBD 4L80E that is used but still in good service. Usually as long as they are not tar whipped they can still be found to be affordable and serviceable and not "need" a rebuild. You do that and add a shift kit and a transmission controller for it to your older truck and it will be a really good strong combo for pulling and driving enjoyment. Way better than having a 700r4 in it waiting to start slipping or th400 with no OD (if you are wanting to stick with an automatic). Having a big block and 3.73's with a good OD and a 275/60-15 tire size (28 inch OD I think??) would set you up for great pulling when you need it plus the ability to cruise all day at 65 to 70 MPH or around that target and still have your engine speeds around 2200 RPM. Alternatively you could maybe check into a slightly taller tire and gain yourself some more RPM's and the big block will still pull. Maybe something like a 31 x 10.50. I think the 4th in the 4l80E is either .75 or .73 (sorry it's late lol) for your conversion ratios and this is the site I use for determining engine speeds with various combos of gear, transmission, and tire size. I have to use it a lot of time to figure out the pulses for adjusting PCM's on LS swaps.
https://www.hgmelectronics.com/gear-ratio-calculator/
This site can also show you differences between tires sizes in general and what it will do to your relative speeds..
https://tiresize.com/comparison/
Hope this helps you on your path to discovery
