dhenderz
- Nov 30, 2018
- Michigan
- Dennis
- K10
I have got both rockers welded into place on the 77 resto project. I also replaced the rocker inners, which are actually just part of the original floor stamping. Also replaced the cab supports, floor supports, inner kick panels & floor sections. I took the cab off the rotisserie so I could temp install the doors. This way I could insure a nice alignment between the rocker and door (bottom). I am noticing 2 things with these replacement parts.
First, they seem to be tucked under the door further than the original ones. Yes, they are straight and fairly consistent. But the original rockers had the appearance of being a continuous extension of the door outer in terms of surface. I need to snap a picture with the door shut to show this more clearly, but here is an enlarged pic from the 511 mile truck that is for sale -
Notice how the surface of the door flows down and around and the rocker appears to be an extension of that surface. The replacement rockers are tucked in about half and inch. So the surface does not appear continuous. Have you experienced this?
Second, the door weather strip flange appears to be a bit too far inward. Below is a pic where I temp installed the weatherstrip. When I close the door it barely compresses the seal. Almost seems like I need to tap the flange outward just a bit to get the seal closer to the door. Thoughts?
