Replacement Jeep Steering / Intermediate Shaft
Vetteman61
Roger
I have a 1987 K5 4x4 (3" lift if it matters)
I have read that the Jeep Cherokee intermediate shaft from 1988-96 is a direct bolt on replacement for the Blazer steering shaft. Is there any particular year in that range that is best? I'm going to purchase a new shaft as I need my truck on the road ASAP and don't have time to go hunting in the junkyards.
Thank you,
Vetteman61
Roger
Anyone?
richard A lindner
Florida
Richard lindner
There is a whole thread on the subject under steering
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Just shoot for the middle of that range. Just go with a 93 or somethin
Catbox
Peter
C20 Silverado Camper Special
I have a '93 I think in our truck.
Works like a champ.
We have pulled another from a random Cherokee in the yard and it looks identical.
Camar068
Kentucky
10 yrs Air Force
get one and install it. Feel free to add any "modifications" to make you feel comfortable. Example, I didn't like the fact that the top side was clamped on and didn't have a bolt through it (like original). So I drilled a hole through and put a bolt through it.
Vetteman61
Roger
Thanks guys, I'm ready through the sticky now.
Vetteman61
Roger
Nice. I have a '78 Caprice (LS swap) daily driver that I've had almost 25 years now and it's in desperate need of a new steering box. I may do a shaft upgrade on it as well.
Raider L
Shreveport, LA
William
@TPlSly-C10,
Man, that's a good looking shaft. And it came out of a Astro? What year? That yoke looks really sturdy. And cleasner than the Jeep one that most guys end up getting.
What engine do you have in whatever that is? Those are factory cast iron headers, where'd you get those? Did they come on the engine? The only factory headers I've seen were on a '67 427, and maybe a '60's 454, and a late '60's Hemi. What have you got there? Where did you get those?
RoryH19
Rory
R10 Silverado SWB
Have one in my k5 from a 94.
While you are there change the bearing and collar at the bottom of the steering column. It's just above the top of the intermediate. Mine was shot and had some play.
Not the best pic but you get the idea.
Raider L
Shreveport, LA
William
@Catbox,
What was wrong with the factory intermediate shaft in your pic above? It looks fine to me. and it has a good looking rubber seal in the upper coupler as well. I had to make a seal out of a new one that was to small. See my thread where I wrapped a piece of 1/4" tubing around the stiff outside of the new seal in order to get it to stay in the bottom of the coupling. The "coupling is the part that the steering shaft goes into that comes through the firewall. It's the thing at the top of the intermediate shaft the steering shaft goes into that has all the grease in it, if you've ever taken one apart. If you don't have to...don't! It's bad nasty! If that rubber seal, "boot" some people call it, at the bottom of the coupler cannot be bought anywhere.
I went through lengthy effort working with a couple of suppliers to finally find out that GM never released that seal for reproduction. Weird, huh?
Catbox
Peter
The joint was pretty sloppy when it was in the truck, so we found the Jeep shaft upgrade and pulled the trigger.
jbahena95
