Rear Speakers
texasmike
Conroe Texas
My after market speakers have an all black wire with a small connector and a black/white wire with a large connector. Which one is positive and needs to connect to the dark blue wire from the radio?
WFO
Texas Panhandle
The wider one is positive.
There's usually a + and a - marked next to the spade terminals on the speaker.
texasmike
Conroe Texas
Thanks Dan, that's what I thought, all black would be negative. I looked and looked on both speakers (made in China) and could not find anything.
Hope all is well in NW Texas.
WFO
Texas Panhandle
Just the usual wind up here.
I just noticed you live in Conroe. My Dad lives on the far west side of Conroe. When he first moved there, it wasn't part of Conroe yet. At that time his mailing address was listed as the town of Cut and Shoot, Texas.
WFO
Texas Panhandle
double post
texasmike
Conroe Texas
Nice countryside out there although that would be east Conroe. If stabbing didn't kill you, they'd shoot you. Ha!
  • Like
Reactions: WFO
WFO
Texas Panhandle
Yeah East. I must'a had a brain fart.
I reckon I was just used to headin West out of Porter to go to his house.
mnsouth
Fairmont MN
Brad
GMC Sierra 1500
I think the previous color markings advice was correct, but you can always double check with a 1.5 v AA battery or a 9 volt battery. When you touch the positive wire to the battery post and the negative wire to the negative battery post the cone of the speaker should move outward each time you tap the wire on the battery, if the speaker cone sucks in, your wires are reversed. Reversed wiring will reduce your bass output. DO NOT do this testing with a CAR 12 volt battery! A 12 volt car battery has unlimited amperage and would fry your speaker !
Raider L
Shreveport, LA
William
@mnsouth,
Is that how you would test a speaker without a + and -, if it moves outward touching the power wire to a post that's positive and if it moves inward that's negative? I re-read your post and I'd have to have both wires connected, but not the, what, the positive wire? If the speaker does what you indicated the + and - are reversed? Electrics confuse me.
jonahhouse
