AKguy
- Feb 16, 2019
- Alaska
- Randy
- K30 Crew Cab Silverado
Okay, 1980 K30. I have the new rear disc brakes mounted on the 14 bolt full floater and am ready to plumb. I used the same calipers as on the front and they have M10-1.5 threads where the banjo bolts normally go. I would like to run hard lines all the way to each caliper. As an option, I could use flexible lines if I had an idea which model vehicle I would need them from that would reach the top center of the differential, then install a three way block. Anyone have experience with adapters for the hard lines or specific flexible line that were used to accomplish this task? Thank you in advance.
