really need the experts on this, runs beautiful won't move
Gman73
Sacramento
Gary
Ck20
350 v8
The transfer case isn’t the issue the transmission won’t engage a gear. When I push the clutch in if I try to select any gear it just grinds won’t even come close to going in gear
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
It's been decades since I had to replace clutch parts, but now I am remembering that they had a short and a long throwout bearing, and they were not interchangeable for function.
Didn't know they had a third style.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Transfer case may not be the issue, but the fact is, it doesn't matter if you tie a rope around the flywheel and attach it to the transfer case, if the t case is in neutral, and the truck is running, the truck will never move lol
I had to edit this, as I realized with a manual, the case can still be in neutral, but it shouldn't grind I don't believe, unless it's right there at the halfway point of engaged/disengaged
Now an auto will grind like a mf if you try to put it in gear with the case in neutral lol
But that is after all always connected, unlike a clutch
Sounds like the clutch isn't ever fully disengaging :(
Gman73
Sacramento
Gary
Ck20
350 v8
good to know I'll do as suggested and give it another try
Vbb199
Salisbury NC
Vince
Definitely would look into the aforementioned throwout bearings, as crappy as that is :(
But if you *havent* tried it with the t case in gear, give it a whirl
Gman73
Sacramento
Gary
Ck20
350 v8
Ok guy's started it with the transfer case in 2 high pushed the clutch in to see if it would get the transmission in gear. no go:mad: the pedal doesn't even have any pressure till about two inches from the floor. I'm guessing it's the throw out bearing. Since I have no place to work on it. I found and old school guy has had a few K's himself says his shop can sort it out. I'll update when he's done
dvdswan
Port Orchard, WA
Dave
T/O bearing not installed on the fork properly would be my initial though. Or the fork has a broken tine on it.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I agree, it has all the hallmarks of clutch not disengaging. That lack of pressure until the pedal is almost on the floor says the same thing.
I wonder if starting it in gear would prove anything other than, it can move on its own. :confused:
Rusty Nail
Rusty
350sbc
I bet throwout bearing
The problem lies with that bearing I bet.
It always does...it's always the throw out bearing...
.ESPECIALLY if you don't know what you're doing..installing the right parts is - kinda crucial.
:rolleyes:
Good luck!
Auburn, Washington
And to confirm, you can row through the gears with positive engagement with the engine off, not touching the clutch?
If so, then adjustment, throwout bearing or clutch fork broke, bent, not seated right on the pivot are the likely issues.
Cantrell299
