Gman73
- Aug 19, 2021
- Sacramento
- Gary
- Ck20
- 350 v8
I know the red feed wire needs to go to 12 volt Battery+ and can be done at the ignition switch, but man that switch is hard to get too. I have a pink wire out of my fuse box that's plugged into the slot that says ignition can I tap into that or could I remove that pink and run the HEI feed there? that pink wire seems weak like it's 16 ga.
Thanks in advance, you guys are the best.
