Quadrajet, fresh built for small block. Ready to run
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Just finished this divorced choke Chevrolet small block Quadrajet. Set up for stock early small block or mild modified.
https://www.quadrajetpower.com/online-store/Chevrolet-350-Quadrajet-divorced-style-choke-p86537097
This Quadrajet is fresh built and ready to ship. The quadrajet in the pictures are the one you will receive.
Fresh built Chevrolet 350 Quadrajet. Will deliver performance for a stock or mild built early Chevy 350.
Fresh complete build with all new internals. external parts plated.
New Float
New accelerator pump assembly with return spring
Bronze bushings in primary shaft
New secondary air valve cam and tension spring
New power piston spring
New jets
New primary rods
New power piston retainer
All new gaskets
New check ball
New vacuum pull off
New fuel filter, spring, gasket and inlet
Comes with new base gasket and air cleaner gasket
Price is $399 plus shipping.
Located in Waring, Tx.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Damn! That would be perfect for my '65, and looks similar to the one on the engine now. It has a lightly modified 350, and could use a properly built q-jet. The one on it was bought from LMC and runs rich no matter what I do to it. Just don't have $400 right now. Crap!
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Well, hopefully this one will sell and we can build you another one when you are ready!!!
You can save a little by not getting the plating. We do the plating on all of our "for sale" builds. Most are custom built to order.
nobodyawesome
