boloboss
- May 6, 2023
- Houston Texas
- Shuntel
- Chevy C10
- v8 350 5.7 liz6er
Thx Manyup vac for ac heat vents. I found some small 1/8 id tubing then took some shrink tube (the stuff for wires ) and shrunk a couple pieces of that on that tube then slide the 1/8 inch tubing over that for a tight fit. then you can hook it up to a vac can .... I just had to put in a new harness for the heater/ac and this is what i had to do for my vac line.. (i had an engine fire burned up most all wires )
