MatDiablo
- Jan 3, 2019
- Lake Tahoe
- Mat
- K10
So, I've just about got all of the leaks sorted on my 1984 K10, but it's still leaking PS fluid. I cleaned it up and tracked it to a leak in one of the hoses.
The only thing that I can see would have caused the leak is the fact that the rubber parts of the pressure and return hoses are rubbing against each other.
My questions:
- is the friction of these two hoses against each other under normal driving conditions enough to cause a leak?
- if so, what's the proper routing of these hoses to prevent this?
Seems like an easy enough job- gonna replace them with Delco parts unless anyone has a better suggestion.
Thanks!
Mat
My questions:
Thanks!
Mat
