Power Door Lock
Silver58
Newort
Randy
I recently replaced the drivers side power door lock actuator and switch with new. Does not activate.The passenger side switch activates both doors fine. Any suggestions on DS?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I believe the power door lock has constant power- have you checked for power at the switch?
Checked for broken wires in the rubber boot that goes between the door and the body?
I had that problem once and it was the light blue wire ...
HTH!
Scott91370
Burleson, Tx
Scott
Sierra1500
My window connector (at the switch) had a broken wire causing the same thing. You couldn't see that it was broken but measuring voltage at the switch show the problem. Once I saw it I move the wire and POP.
brantley
