wayfastwhitey575
- Nov 17, 2022
- Cyrl
- C10
- 350 vortec
I have a 1980 C10 and I just installed a new transmission crossmember with the "W" so when I run my exhaust it will be tight to allow for ground clearance. The issue I have is that the parking brake line crosses over just aft of the crossmember and it will be right in the way of the exhaust where it passes under the transmission crossmember. Does anyone have info on rerouting the brake cables? It seems simple enough but if anyone has previously done this pictures and info would be helpful. I would like to keep the parking brake and not cut the cables. Thank you.
