Order in the court.....
Doppleganger
OH-MI: Just like it sounds
Getting ready to strip my K20 down to the frame. Hoping to get the frame painted, my axles rebuilt and in, along with the motor/trans and suspension. Figure the weather here is so lousy 8 months a year, the sheet metal will have to wait til Spring.
QUESTION......is there any particular order in assembling things? What I'm getting at is - would you set the cab back on the frame before running brake or fuel lines, maybe headers.....to avoid any interference problems? I've got new tanks and figured the bed being off would be easiest to install them and new lines.
Stupid question but I'd rather ask it now than later when/if I have some of the aforementioned issues.
Thanks.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
When I did my k5, I did it based off of height of the truck...
(bare in mind this is a lifted truck)
I stripped the body completely down, separated the frame.
Starting with a bare frame, I used the axles as saw horses and set the frame down on them.
Dropped the motor in, bolted it down.
Put the suspension under the truck, then attached axles.
From that point, I was able to do all the wire wheel work, sanding, painting etc to the frame.
I attached an exploded 4L60e to the big block just so the motor would situp right, and it mock it up as if everything was level, using the crossmember and blocks of wood under it to level the whole setup.
Bolted on headers at that point to see if there would be interference in the frame.
Also attached the 79 front clip, rad support and all to see how it would all turn out. Even mocked 79 fenders up to check tire clearance.
(the following part doesn't pertain to what you're doing) once the transmission tail shaft was pointing parallel with the frame, I then welded up my subframe/cradle for the drop box.
Moving on to your part...
Once all subframe work was done, frame was prepped, painted, brake lines like I wanted them, I rolled the frame outside to where I left the body, then picked the body up with a outdoor gantry I made, and rolled the rolling chassis under it with smaller tires.....
Then rolled the whole rig right back under the carport....
It's been sitting there since as Ive been working on it, adding stuff, etc.
Putting the motor in first is definitely a good starting point.
Axles are alot easier to slide under and bump back and forth on their Centerpins without any weight.
I did all of this worth with no concrete, all in the dirt. Just have to get creative.
Vbb199
Salisbury NC
Vince
Only thing I didn't do was wrestle the th400 in while the body was off.....
That was my one mistake.
But I didn't have it ready to take a beating from a big block just yet.
Ohhhhh !!! Dis gonna be a good one to watch !!! :waytogo:
hoagster
California
K10, 1500
5.3l
Take your time, It's a lot of cleanup. Take lots of pictures during the tear down so you have something to refer to when it goes back together. Ask away when your looking for something! And Thanks for for the kudo's @Craig 85
Doppleganger
I'm already in over my head.....only truck I have is the one that will be in pieces and I'm condemned to a place with no shop, plastic rusts and weather is crap 8 months a year.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You can do it, I have faith in you. Much easier than navigating through a Volvo...
ali_c20
Austria
Alexander
C20, K5
I did frame, axles, brake lines, fuel tank, fuel lines, engine, transmission, everything that is not connected with the cab. After engine break in I did all the metal work and paint off the bottom on the cab. After that cab back on frame. After that the remaining 125.789 things that were left to do.
https://79k5build.wordpress.com/
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Maybe @Keith Seymore can help us out here. but I'd try to put it back together in the same order that the factory did it. They would have a handle on the most efficient way to assemble a truck.
My thinking is frame, axles, fuel/brake lines and other attachments like chassis electrical, tanks, engine and drivetrain, exhaust system, rad support, radiator, bumpers. Then as ali_c20 said when you've got everything you can put on without the cab, put the cab on. Then more electrical, fenders and the rest of the front clip. Bed would be last. If I had the opportunity I would also try to paint the body while it's off the frame. You have better access, and don't have to worry about overspray.
Doppleganger
Thanks fellas - some pretty awesome builds on this site. Hoping mine comes out just half as good.
My goal is to get the frame, axles, suspension, tanks and the motor / trans in place. A real win would be to get the bed and cab in color and back on.....can spray it again in place if need be. Glass, wiring, etc is the finale. I've got a really slick cover for it when the drop back and punt time comes for next Spring.
Just alot to do at the mercy of the weather in a state where the weather sucks most of the year. lol
fr3ak5how
