MtBraun
- Sep 27, 2017
- South Dakota
- Matt
- K10
Hoping someone else has installed these. Per instructions, I broke leaf spring pack down to one leaf, inserted spacer and mocked up rear axle to the frame. ORD says to cycle the suspension to find the least travel in mounting location. That part doesn't make sense to me. I would think the best geometry with the least amount of end movement would be with the traction bar at the longest length. Also, at what point in leaf spring compression should the traction bar be mounted to the frame? At full weight or something else?
Lastly, for the axle mounting tabs, I was going to clock the pinion angle to 3 degrees to get it close and weld the tabs plumb with the tube. I won't be able to set pinion angle until the very last step of the build so I thought this would be close enough, plus the tabs allow for enough movement in adjusting pinion angle.
Thoughts?
Thoughts?
